Hal9000
OK, so I'm getting ready to cut and thread the new track bar for my FW front axle, and I've been doing a little measuring.... And of course that means that I've found that things aren't as I thought they would be.
Using the stock trackbar mount on the frame and the '79 BB axle with stock steering components and my 4x4x2 box with EB pitman arm, My trackbar angle will be exactly the same as the drag link or maybe a little steeper. (If I remember that steering geometry diagram right, this is what I want). If I go with a FW trackbar which was my plan, The trackbar angle will be a little more horizontal than the drag link.
Since I'm fabbing my own trackbar, I'll be using Heims at both ends (easiest way to do things I found) and a straight link with no bend to clear the pumpkin. Using the stock mounts, it looks as if I'll have about 2.5" clearance (conservative estimate) between the pumpkin and trackbar at ride height. I'd have a bit more if I went with the FW bar, so if 2.5" isn't enough clearance then I may have to go with the FW bar....
Sooo, show of hands (or threads). Do you guys think I should even mess with the FW trackbar?
