- Joined
- Feb 2, 2006
- Messages
- 110
Been having trouble with my new blueprint motor with sniper efi where the ecu does a "reset" and the computer basically restarts, especially, but not only on higher throttle situations. The holley forum guys all seem to believe this is an EMI/RFI problem. If you look at data logs you from the sniper everything gets wacky and reasdings revert to negative times etc. I did a test running the motor without an aircleaner and had the spark plug wires and distributor wrapped in aluminum foil and it seemed to run fine for the entire test. As a result I bought some MSD super conductor spark plug wires, spark plug wire looms that runs the wires to the front of the valve covers before going up to the distributor, and a smaller diameter aircleaner that doesn't touch the wires at all. I got the new stuff all installed last night and took a test drive today. I was able to go for a couple mile drive with almost no problems, but had what looked like a quick reset twice in that drive. I got home and let it idle a bit and started having more and more resets to the point where it would barely run. It appears I sadly have more work to do.
What other things have people done here specifically with their Broncos to address this seemingly common problem with these units? Next for me is a plastic air cleaner stud and to start playing with some ferrite beads. Some people have recommended a different distributor cap. There is a Holley "hall effect" distributor that is plug and play with sniper units. Hopefully can avoid that as its $$$
This is so maddening because Im so close to being able to just take my Bronco for a drive for the first time in basically a decade
