holly projection
demesauce
Shaver Lake, CA
I run one on my 351w. Works great. Tuning was simple and like you said, it's cheap. Very cheap compared to efi systems. I don't have an o2 sensor/setup and it still functions great.
Pro-Jection indicates it predates the Commander system.
Even in the Pro-jection series there are a few different flavors. They can be better then a carb, they are often worse. I had one of the top of the line versions the 4Di with O2 sensor and laptop programming. I had to find an old laptop to do the last tuning on it, the newest operating system it would run was Windows 95, first edition. Get the update and the laptop will no longer talk to it. That was the good version of Projection
The typical "good deal" version is the 2-barrel analog system where the controller had 5 screws. Usually mounted in a handy location because you always had to play with the screws to dial as you drive. Not a one time dial in, but like a dial a jet you tuned as the weather changed. In the late 80's and early 90's this was the bomb, now it is just a bomb.
Honestly, even the top of the line late 90's digital feedback programable version wasn't that great. By todays standards, pretty much worthless. I would buy a carb before a ran a free Projection these days. I defended my choice to get that system long enough. Reality has set in, it wasn't that great.
Now if it is the Commander 950 system, there is some hope. But you specified Projection, so I would pass.
demesauce
Shaver Lake, CA
I have to disagree, completely. I run an old analog version, one of the first 2 barrel versions. Once I followed the tuning directions, I haven't had to adjust it once. And I live in a climate that hits 120 in the summer and drops to the 30s in the winter.
Carb are pretty worthless in any off camber situation when off roading, even the Truck avengers.
Do not run a 4 barrel TBI setup, that is way too big for a small 289. I had read poor reviews with the analog TBI systems, but I have not experienced any of them. It was a little difficult to find the fuel pump specs when i had to replace mine, but now I am all setup and running strong.
wesleydax
buddy of mine has had one for several years and has had no problems with it.
SteveL
Huge chevy guy
Hawthorne ca
The 72 suburban i bought has some kind of 2 barrel holley injection on it. I works like crap. It's going away soon as I get around to doing a summit order.
Bronco Junkie
So Cal Broncos
My Motorcraft 2 barrel works great...even in very off-camber situations. And even though I have a LUBR that does not mean it does not get off-camber. I can show you some brown shorts from my buddies if you want.
