Pro-Jection indicates it predates the Commander system.
Even in the Pro-jection series there are a few different flavors. They can be better then a carb, they are often worse. I had one of the top of the line versions the 4Di with O2 sensor and laptop programming. I had to find an old laptop to do the last tuning on it, the newest operating system it would run was Windows 95, first edition. Get the update and the laptop will no longer talk to it. That was the good version of Projection
The typical "good deal" version is the 2-barrel analog system where the controller had 5 screws. Usually mounted in a handy location because you always had to play with the screws to dial as you drive. Not a one time dial in, but like a dial a jet you tuned as the weather changed. In the late 80's and early 90's this was the bomb, now it is just a bomb.
Honestly, even the top of the line late 90's digital feedback programable version wasn't that great. By todays standards, pretty much worthless. I would buy a carb before a ran a free Projection these days. I defended my choice to get that system long enough. Reality has set in, it wasn't that great.
Now if it is the Commander 950 system, there is some hope. But you specified Projection, so I would pass.
