I heard that the high pinion 9 had an 8.8 ring gear
The Currie High Pinions (CHP) do use a 8.8" gears, the TruHi9 uses reverse spiral cut 9" gears. Although the 8.8" gears are slightly smaller the main difference in strength comes from the third pinion support bearing on the TruHi9 (they both use 9" carriers/lockers). For a front application they will both be stronger than a D44, the TruHi9 will definitely be stronger than a D60 and the CHP will likely be relatively close to the D60. For a front axle if you are spending the money to build a 609 housing, I would use the TruHi9 other wise you really aren't getting anything better than a HPD60 except a non cast 9" housing.
In a rear end where reverse spiral cut gears will run on the coast side creating much more deflection force there is a huge advantage to having the third pinion support bearing of the TruHi9..
Unfortunately the TruHi9 is substantially more expensive then the CHP thirds and have to be setup by TruHi9. The CHP can be bought in pieces and built by anyone capable of doing so.
With all that said I have a CHP in my rearend and have had no failures yet
