home made radius arms....help!!!!!!!!!!
Horsebeat
Has any one out there made tubular radias arms.
* What size of tubbing did you use?
* bushing or heim?
* did you mount them under or on the side of frame(using full width 44)
Any help/pics would be great!!!
66Gasgrill
Canton, NC
1.5" x .375" wall tube.
3/4"x 3/4" FK heims
Mounted under the frame. Fullwidth 79 D44 w cast wedges. No problems
H
Horsebeat
Thank you so much for your in put I've had broncos my hole life but I decited to do a frame up and want to build it up right the first time right now Im running the stock d44 with jeffs chromo axels and an ARB and never broke an axel do you guys have any input on the full width d44 compared to a d60 keep in mind I can get a d44 for 300$ or a d60 for 1000$ but by the time I rebuild the d44 I would have mor than if I bought the 60 ??????????
66Gasgrill
Canton, NC
I agree, In the long run you will probably spend less on the 60 vrs. tring to keep the D44 alive. I have been through several sets of ball joint countless axles. hubs. Don't get me wrong my 44 takes a lot of abuse and holds up to most of it but every now and then it goes bad and I wish I had built a 60.
H
Horsebeat
Thanks agin guys I will more than likley buy the 60 but just though I would ask everyone in New Mexico runs 60s so Id better follow suit.
airman
Do it right the first time.. Got a buddy that has just over $650 in a D44 and still needs moly shafts.. Go with a D60..
I hear that. I have the moly shafts and tough ujoints. I have rotated my knuckles for pinion angle, add in detroit locker and disc brakes, I have easily spent $1200.00 on my D44.
A week ago I just saw the coolest thing on BC's website. Its a (" housing with D60 yokes set for the caster you want. Now I can see the end of that rainbow costing me near $2500.00 but how sweet would that be! Imagine High Pinion 9", 35 spline selectable with D60 outer shafts. Its almost a rockwell.
scsm76
Shaver Lake, CA
I heard that the high pinion 9 had an 8.8 ring gear
The Currie High Pinions (CHP) do use a 8.8" gears, the TruHi9 uses reverse spiral cut 9" gears. Although the 8.8" gears are slightly smaller the main difference in strength comes from the third pinion support bearing on the TruHi9 (they both use 9" carriers/lockers). For a front application they will both be stronger than a D44, the TruHi9 will definitely be stronger than a D60 and the CHP will likely be relatively close to the D60. For a front axle if you are spending the money to build a 609 housing, I would use the TruHi9 other wise you really aren't getting anything better than a HPD60 except a non cast 9" housing.
In a rear end where reverse spiral cut gears will run on the coast side creating much more deflection force there is a huge advantage to having the third pinion support bearing of the TruHi9..
Unfortunately the TruHi9 is substantially more expensive then the CHP thirds and have to be setup by TruHi9. The CHP can be bought in pieces and built by anyone capable of doing so.
With all that said I have a CHP in my rearend and have had no failures yet:eek:
