45acp
hello guys. im about to start my rear disc conversion, and have a question. i already have a set of weld on race car brackets and loaded Monte Carlo front calipers, and need to pick a rotor. seems there are a lot of varying ideas on what rotor to use. i wont be using an Ebrake setup. what rotor should i use and why? should i run them in front of the axle flange or behind it? i have cheap machine shop access and can have the axle flanges turned down no problem. are the rear lincoln rotors 5 on 5.5 or will i need a set re-drilled to that bolt pattern? if at all possible, i would rather go with a small-ish rear rotor and not use the same as the front so i can possibly get away without running a proportioning valve (just trying to keep costs down).
thanks for the help guys.
