Hood insulation
I think it’s been pretty low on most people’s lists, which would explain it not coming up often in the vendor’s catalogs.
But I’ve always felt it was beneficial enough to do. Just because it didn’t come from the factory on a bronco doesn’t mean it’s not a good idea.
After all, it came either stock or as an option on practically every other vehicle out there.
If it reduces a little noise, protects the paint longer from excessive heat, or even keeps the area over the cowl cooler by a little bit (likely keeping the interior cooler most likely) it sounds to me like it’s all good.
There was one aftermarket company that had it in their brochure. They used to show up at car shows and they make different products for different people for different areas of vehicles.
Can’t member the name of the company at the moment but they seemed to offer one that had a nice finish to it. Same thing you’d find under a muscle car hood with a logo on it.
I’ll see if I can find it.
And all the logic listed above was the same reason I always thought we should have coil spring insulators on our front suspensions.
Just a little more isolation from noise, even if it wasn’t much.
I always thought even in small increments, a little help here and there always adds up.
A
Adam D
Newbie
DirtDonk,
Good insight and I agree. Going to shop it a bit more (and talk to the guys at Wild horses).
Cheers!
Qumanchew
Kutztown PA
I'm interested to see if you can find anything. I've searched and couldn't find anything I liked. Everything I've come up with has the foil face, which I'm not liking just from a looks stand point. If you search on a boating forum there is a lot of discussion on the topic.
