Banjer Picker
- Sep 25, 2006
- 1,357
Do I hook the hot wire directly up to the pos terminal? What are the other options?
THanks!
Brandon
THanks!
Brandon
i would go direct connection i want max power available when im stuck. ive seen people put shutoff switches between winch& battery but they need to be high amp to handle the load.
Also, it pretty much insures you won't have problems with someone vandalizing your bronco by free spooling the cable out, wrapping it around your vehicle....then using a paper clip to activate the winch via the remote receptacle (called taco-ing a truck).
Just install it on the negative terminal. Always run your leads directly to the battery for best performance.
I wired mine to the side post on an Optima and it melted the post out ,then after more research the side post is not designed to carry that much load.
If you want to keep it vandal-proof then you need to keep the key out of the switch, not wired to it. I personally think it's easier and better to wire in a solenoid cut-off switch inside that kills the solenoid activation current only.
It doesn't matter where the battery switch is installed it's still limiting current.
Devils advocate here : If the solenoid sticks in the on position , killing power to the solenoid won't do anything , it's stuck in the on position.
I've had that happen on starter relays ..... that gets the adrenaline going !
Start truck ... release key ...starter still grinding away ... first instinct , dump the clutch to kill the motor .... oops ... truck lurches and refires cause the starter is still grinding away .... buddy who was there realizes what's going on throws hood open and manages to pull battery hot off bare handed in one shot ..... deep breath ....light cigarette and go clean britches.
