As much as I like HP too mine are all tuned for 87. I tend to spend a lot of time off the beaten path and often only 87 is what is available.
Add a little more boost with the 87 tune...I’m surprised the 91 octane wasn’t good enough up in the mountains. The elevation supposedly makes a difference.
I think I’ll just always carry some octane booster for an emergency, but then again maybe I just follow Brian’s advice, go with the 87 octane tune, and live worry-free. I have some time to make this decision because the controller will be one of the last things I buy.
I haven’t asked yet. I was saving that for later. I can’t see it adding more than 15 hp, so probably not worth the pain and $$$.Add a little more boost with the 87 tune...How much more aggressive will the 93 tune gain you in HP over the 87 tune?
Dish the pistons?Until good old Ford Performance build an engine with the wrong pistons in the wrong sized holes, I was fine w/92 octane.
After the heads got shaved and the block got redecked and the new cam is tighter on overlap, (which the guys behind me will appreciate now) because they could smell sunburnt gases hundreds of yards behind... anyway, it all added up and I rattle now at 1700-2400 rpm under load.
