hot suspension set up?
shawn's 68
Hey guys, just finsished getting the frame off and started scratching my head as to what the hot set up would be to install in the bronco. I plan on doing some medium duty trail riding and comfort to me is a huge plus. I plan on installing the one inch body lift from wild horses but was curious on suspension ideas, thanks everyone!
wesleydax
ive got a 2" body and 3.5" suspention, progressive coils and 11 pack springs, dual shocks. It rides better than ever and does well on mild trails.
needabronco
Prescott/Farmington
Buy a good suspension system and throw the shocks away, buy a good set of Bilsteins and don't look back. Don't waste time and money on dual shocks, you'll get a much better ride using one properly valved shock per corner.
I like WH suspension systems. I have a 3" CITI coil springs up front and WH 3.5" leafs out back, up front I run single 10" Bilstein 7100's and single 12" 7100's out back. I also have a 1" body lift and run 35"s and can run 70-75 on the highway all day long, I can bomb down rutted washes, and rock crawl fairly well.
thepunisher
summertown,
I'm in your boat, I'm set on the 1bl and the 2.5inch 11 pack deaver springs, long arms, spring rockers. But I can't figure out which coil spring has the softest ride and the most flex, linear or progressive rate springs?
Oakland Bronco
San Francisco, CA
Pic 1 should be in the calendar :cool:
shawn's 68
shawn's 68
Heres a question for you guys. I definately want to put a lift, but would like to get away with out cutting the rear fenders. Is this possible? And if so, what are my limitations?
70_Steve
Old Guy
Absolutely!!! Do a search on LUBER. No issues with doing the suspension lift. your limitation will be on tire diameter and width.
My suggesion would be to stay in the 2 1/2 to 3 1/2" suspension lift range. No real need to buy a suspension "system" from the venders as long as you feel confident you know all the pieces you'll need. I had 2 1/2" Wild Horses progressive coils, and 11 leaf springs in the rear. Rode very well and handled pretty decent as well.
X2 on needabronco's comments about shocks. If comfort (good ride) is important, you will absolutely hate any double shock configuration. I ran (still run?) Ranchos for a long time, then put Bilstein 7100 in the front. OMG! There's no comparison, both for smooth ride on the street and off-road performance! Medium sized bucks, but worth every penny!!! The next project (after I get my engine back together... :cry:) is to build rear shock mounts so I can put 7100s on the back.
rguest3
WH actually started with their 2 1/2" lift and then deducted the shocks from the total. So, I saved a little there.
I also went with the 5100 Bilsteins and they seem to match the lift extremely well and very comfortable. No complaints.
Will be adding the WH 1" BL this weekend in preparation for 265x70x17s. Front and Rear are Uncut.
