HOT wires!!!
bluebronco69
Damascas, OR
i have aux lights (55w procomps two of them) anyways it is wired thru an aux fuse block which is connected to the factory "hot post" under the dash by the stock fuse block.
the problem is i was feeling the wires and they are really hot when i have the lights on (they were on by accident) anyways it is the wires on the light side of the aux fuse block and the wires going to the lights
maybe i can make a diagram it is also a 20 amp fuse should it be less? maybe a relay? what is wrong here i have heard of this problem before but cant remember the answer thanks
there is a drawing i made to show this problem better here is the link
http://www.broncofix.com/viewtopic.php?p=1049461#1049461
it is at the bottom of that page i kinda mixed posts on that one but ya
thanks
joser
Chesterfield, MI
Try this. I got this from somewhere on this site. I think Saddleup posted it.
The power CANNOT go through the switch. See if this picture makes sense.
Good luck.
69red
Cochrane, AB,CAN
Another key point that the diagram doesn't show is that you want the wire from terminal 87 to the lights and the wire from the battery to terminal 30 to be as short as possible. this minimizes voltage loss.
the length of the other wires does not matter since they do not carry much current.
bluebronco69
bluebronco69
Damascas, OR
so a relay would fix all of that? what kind? where do i buy it? what kinda rating does it need i have never really delt with relays before so i dont know what to look for
thanks
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
I am using a 70 amp relay from NAPAfor my aux fuse box, about $20. It's over kill, but I don't know what I may add to it in the future. I run a standard 20 amp relay for each pair of lights. Your pair of 55wers will be drawing close to 9 amps.
bluebronco69
bluebronco69
Damascas, OR
ok ill look for like a 15 amp relay at napa or whatever also i am jsut running i think 12 or 14 gauge we use that for like most everything on the cars is that ok? also the fuse in the aux fuse block is 20 amp is that too much maybe should i step down to 15? and is there any trick to hooking up the relay? from the way i hear it it is 12 v in, ground the relay, the wire out to the lights and the wire that goes in from the switch on the dash. is that all correct? thanks you guys
Mr Joe
joser said:
Does anyone know how to convert the wattage of a pair of lights to how many amps they will draw???
Watts / Volts = Amps
RRRAAAYYY2
Brantford, Ontario
Sometimes it is also [Watts/Volts = Amps] x efficiency. In the case of some, not all, lights they put out 55watts of light and 55%watts of heat, as they are only 50% efficeint. This means they need 110watts of power in. So in a 14volt system they would need about 8amps each, instead of 4.
Then you could throw in voltage drop on the wires, which would increase it even more. Here is a link to a wire sizing chart: http://www.svapowerproducts.com/html/bw_chart.html
