OK, so after moving into our first house last November life has been busy but fun as of late. Have a nice 3 stall garage that I got heated and insulated, 220 plug for the welder, all of this just in time for winter to be over
But, nothing got done on the bronco since last summer so the last two saturdays I finally made some forward movement. I have had both new quarter panels from Jeff's bronco graveyard for the past few months. I have cancer at the bottom of the quarter and along the seam. The driver side is also all bunged up with dents and multiple gas tank drillings. SOOO time to Finally get after it.
I started by cutting a couple inches from the seam to access the spot welds. Then I was able to get at the many, many spot welds. The tough part is actually the two areas where the quarter is "sandwiched." The first part is lower rocker area and the second the taillight housing area. I tried to take a pic to show that.
This is a real PITA! I had to use by screwdriver and use as a chisel and basically bust out all the welds in these two areas. After you get through those two it is smooth sailing. I went through about 3 harbor freight spot weld cutters. I now have purchased a nice Blair made in USA spot weld cutter that can hopefully last a little longer.
