How do you get this off?
boogie
Lafayette La
How do you get this off? Im working on getting a lift off and need to change the pitman but cant get the ball joint (if that's what its called lol) off. I don't want to beat on it till someone says to beat on it lol Thanks
70_Steve
Old Guy
... but cant get the ball joint (if that's what its called lol) off. I don't want to beat on it till someone says to beat on it lol
Tie rod end.
Yes beat on it, but carefully. I use the "Double BFH" method. 5 lb hammer on the back side, then hit the front side with a 2 lb hammer. The 5lb backer takes most of the shock. The objective is to just slightly deform the tapered end of the pitman arm so it will let go of the rod end. You don't want to just smack straight on the pitman arm without something behind it, since that shock goes up the sector shaft in the steering box, and may damage gears, etc.
Leave the nut loose on the top of the rod end. You'll see when it lets go. The rod end will drop to the nut.
TN1776
It might be easier (if you have access to a press) to pull the pitman arm and press the joint out.
But if not, the above methods can all work too. I used the pickle fork linked above but was not at all concerned about preserving the old tie rod end.
Hozr
Rogue Valley, OR
If it's REALLLLLLLY stuck a little heat never hurt. On the pitman arm not the ball joint unless you are going to replace it.
driveshafter
phoenix az
p arm
you can buy a puller for about 50.00 at auto zone they work like a harmonic balancer puller with a clamp that goes around the arm and a boltto tightnen to pull the arm off
boogie
boogie
Lafayette La
I got it off but the little ruber pice is done I hope I can chage it?
Wyflyer
I like to put the big hammer on the tie rod bolt, and whack the arm from below. Doesn't take much
