Is the clunk occouring when you are going over bumps? There is no reason the hub would be going bad if you only hear it in 2wd and driving normal. I was thinking over bumps because maybe your front bearings are going bad. If you jack up the front end and stand next to the tire, and you grab the tire top and bottom and shake the ends in opposite directions (top towards truck, bottom towards you, in a riciprocating motion), you should have very little movement. The tire shouldn't shake more than maybe a 1/4" at the top of the tire. If you get more than that, then your bearings are probably shot. Make sure you do inner and outer if this is the problem. <br> Besides that, once my wheel caps were not really smashed between the rim and the hub very well, and it caused the cap to sorta bonk around at slow speeds when it would fall to a new position due to gravity. I put a little bit of silicone between the cap and the hub and the noise went away because the cap was no longer able to move. Good luck!<br>-Eric
