I have been pushing the stock 60 amp alternator fairly hard for years now. My truck draws a good bit of juice in a normal drive with twin fuel pumps, fuel injection, electronic transmission. Get a cold wet drive and it gets worse with twin wiper motors, blower motor, lights, and even heated mirrors.
I don’t worry about the winch too much, the power load the winch demands is well above any mortal alternator. That is why they run off a battery. The alternator just tops off the battery after (or tries to during) winch use. If you are doing back to back, pull after pull then that is a different issue.
The charging system keeps up at idle with a full load. But it didn’t always. The crank pulley has 2 different sized pulleys. The small one runs the waterpump and power steering. The larger one runs the alternator. At one time I didn’t have power steering so I ran the alternator off the small pulley so it would work the water pump. That didn’t charge that well at idle. When I went back to the larger pulley, I started getting a good charge at idle.
At one time I even lost 2/3’s of that 60 amp alternator. I would run a deficit at night with the lights on. But the next day after driving around with the light off to get the new alternator I was back to a full charge. I know my normal cruise (daylight, dry day) is under a 20 amp draw.
14 years ago back when I ran a carburetor, I drove for over a week after I noticed I completely lost my charging system. The wipers would barely move on high and the lights were dim, but it would still start and drive around town.
I do have a modern alternator sitting in the garage that is going to go onto the Bronco. Not because I want to upgrade it, but only because it is part of the short Explorer front dress that will let me run a nice clutched fan and A/C.
One great thing about the stock 60 amp unit that is often overlooked is that they are affordable and easy to rebuild. I think that somewhere they have a trained monkey sitting in a room with no lights rebuilding them. Back when the alternator died on my BroncoII, the rebuild kit for the internally regulated unit was more expensive then a whole, good rebuilt external regulated alternator.
How much of a problem are you having with the current alternator output?
And adding a ground won't do squat. The alternator is grounded to the engine. Make sure the battery ground to the ENGINE is good. Also helps with starting the engine as well.
