I understand about the WiKi
While I can't find a specific PDF on the Rotella Joe Gibbs Racing seems to have the same info (more indepth) on their Driven Oil site.
Back in August of 2005 (less than a year after API SM was introduced), the Society of Tribologists and Lubrication Engineers published a story stating that calcium-based detergents and dispersants competed against the ZDDP for surface space, and that caused some wear issues in passenger car engines. Around this same time many engine builders began to experience a rash of flat tappet cam failures during break-in.
The level of ZDDP had also been reduced in the API SM oil spec, and along with the increased use of calcium detergents and dispersants, the critical balance had shifted. The results were nearly catastrophic for independent engine builders and camshaft manufacturers. The rate of flat tappet cam failures escalated at an alarming rate.
The decrease in ZDDP from 1,000 ppm down to 800 ppm was called out as the cause for the rash of cam failures. This failed to take into account the change in ZDDP to detergent balance. Many engine builders switched to diesel oils that contained higher levels of ZDDP, and that worked sufficiently until the diesel oils underwent a reduction in ZDDP down to 1,200 ppm in October of 2006. By the end of 2007, engine builders were again on hunt for a higher Zinc solution. This time, many switched to properly formulated break-in oils high in ZDDP and low in detergent. Some still held onto the diesel oils, but also added an off-the-shelf ZDDP supplement.
http://www.drivenracingoil.com/news/dro/training-center/articles/zinc-in-motor-oil/
Tim
Tim
