byrdman03cars
- Oct 29, 2012
- 3
I have a 1970 bronco, just installed James duff 3.5" ultimate suspension package with drop down/adjustable radius arm brackets. I have 7 degree axle wedges, drop down pitman arm, drop down track bar bracket and adjustable track bar. The current readings on the front end are camber left 1.1 degrees, right .7, caster readings are .1 left and .1 on the right, and toe in is .20 left and .17 on the right. The bronco drives fairly well, but still feels super sensitive while driving. I was hoping to get to 4-6 degrees camber. Is there anything else I can to to reach this?
Thanks in advance for your help
Sam
Sam
