How to remove front seat
abrdn419
I just got a 77 bronco and i want to replace the front seats I was wondering I need to remove my aux. gas tank to remove the drivers side seat. Are the nuts welded to the floor pan or are the free moving. And what seat recomendation you guys have.
red76
Raleigh, NC
For the recommendations consult the link above. You can remove the seat with a set of box end wrenches and the tank does not have to come out. I'm not sure if the holes are threaded or there is a nut welded on the underside but you do not to have access to the underside.
Good luck
Will
desertbug
Fallon, NV
I don't have the aux tank, but if I remember right, the bolts holding the brackets in on the driver side went into "attached/welded" nuts on the underside. Wasn't that hard - 4 bolts on driver side, but several more on the passenger side (bolts in front only).
If you're going to look for seats, here's an idea of what I did... I used Bronco II seats because the rail size was the same. I only had to drill 2 holes in each new seat bracket and they slipped right in. Covered em up with some seat covers from Kragen and improved my comfort for less than $70.
Here's the link to the post:
bug's seat post
Good luck! ;D
