Tighten, loosen. Repeat twice. Should seal
There is wisdom in his post…
With new inverted flare fittings and seats, it is often necessary to “set” the connection by crushing the flare. That might require “over-torquing” initially…then relaxing the connection and re-tightening to the correct spec.
Drives me crazy when lines are either under-crimped, (and loosen and leak.) or when over-tightened and left that way. (And then rounded off when serviced later)
Do what nickgp says. tighten, loosen, and then tighten correctly. This is not necessary for tapered thread, or o-ring, or compression. Just new flared connections.
