pcf_mark
- Jun 11, 2010
- 3,584
My 73-74 power steering box has been leaking from the sector shaft seal for a looooong time so today I decided to pull the seal out and replace it. In the order in which I removed the parts once the pitman arm was off
snap ring
washer
seal (more like a rubber washer)
lip seal with the open end facing into the box
When I look at the repair kit it includes two washers, two seals and a snap ring. Do I need this second washer? Is it included because the new seals are not the same thickness as the old seals? The stack of seals and washer was right up against the snap ring not sure how it would fit. It appears to be all 100% OEM.
My sector shaft looked good I am hoping the seal dried out. The used box sat in a container for 10-15 years before I installed it. No play in the sector shaft at all.
snap ring
washer
