OldBarnBronco
- Nov 25, 2009
- 87
I bought this system last summer and it worked great the first few
months. Now however I regularly get a code 44 and it runs rough and my separate AFR gauge drops to 10. It’ll run great the first time I take her out but if I shut down and then start her up again the she quickly throws the code 44 lean condition detected. Fuel pressure is 10-11 so it’s ok. I checked and cleaned grounds and hot leads and all looks good. One other weird thing it does is when I plug the code reader into the ALDL link and turn the key to the run position I hear a rattling type sound in the throttle body and then I see gas leak out around the throttle shafts. It’s not running of course only the key is in the run position. Thanks for any help.
