I put a 94 GMC Sefari hydro boost on and am using the stock pump with a T fitting on the return.
I just drove 20 miles and it felt like the brakes were not letting go all the way.
I am running the stock distribution block with front disk and rear drum.
Helpbme out here but i think my return is clogged or the T is causing feedback.
i will pull over again in a bit to pull the return fitting off the hydro to check and see if if is clogged.
My rims were hot to touch so i know it is holding some how.
