- Jun 4, 2002
- 35,059
Wrong! There are some heavy trucks with full hydro steering, along with some of the newer high-end cars that are "fly by wire," and have no mechanical linkage for the steering. They are perfectly legal to drive on the street in all 50 states.
I've driven a couple of well-built full hyrdo rigs on the street, they were great and did self center. And, contrary to some opinions, you DO still have steering if the engine quits.
The drive by wire cars still have a hidden mechanical link. At least all the road worth sellable ones I have seen do. Prototype/show cars (GM Hy-wire?) don't need to comply with safety standards and can do whatever they want to impress us.
If you want to get spooked a little, the Pryis hybrid thingy has completely computer generated brake feel. You press a master cylinder, that pushes brake fluid into a 42 volt brake control module that tells the hybrid system how much generating power to make to give you the feeling of brakes working. The brake pads only work at parking lot speeds or heavy braking. But if you do loose power to the brake control module, the default is non-power brakes. Every new car I see now has drive by wire throttle, even the cheap Kerean cars. And for more fun, the power steering is ditching the engine driven hydrolic pump and going the a electric motor that is also computer controlled and in the column or the rack.
Last I checked there has to be enough redundt systems to bring the vehicle to a safe stop (steering and brakes) in the even of a complete vehicle power failure (engine stops and no eletrical). The big trucks running full hydro have accumulators (I just tossed the info that had the actual SAE spec that they should meet) to give redundent power after a system failure.
