teqoso said:
I need to modify my steering pump system to put on a another return line o the pump for the hydroboost system. My question is, I am running BC Broncos heavy duty pump and have been real happy with the pump. I also do not want to go thru another pump and mounting system. Can I just drill and tap another return line onto the pumps neck, just above the mechanism. Is the possible or should I just break down and convert to saginaw?
First of, Chucks pump is a Saginaw pump.
Second, sometimes the T method works sometimes it does not.
Third If your pump is the standard configuration pump, probably is, go to the Upull yard and get a dual return can. Any diesel ch**y pickup should have one. Get the whole pump, but all you need is the can.
Get a seal kit from the auto parts store, put the dual return can on your pump using the new seals in the kit.
Follow the bleed instructions for a new installation RELIGIOUSLY, and things should get fixed real quick.
Learned the hard way about this one, in my install the T install worked but not well. Got the can off a diesel pickup, made the change big difference.
TOFIC
