Hydroboost Questions-Mounting Bracket
rcmbronc
Tomah WI
Sorry to ask another hydroboost question, but I cant really find the answer. I want to install a Astro hydroboost that I have in my 76. It is a 351W with1" body lift. No factory power brakes. It ahs the Ford Motorsports valve covers which are quite tall. Do I need an angled bracket like the vacuum booster uses or just an Astro angled bracket?
If just an angled bracket, what is the max angle that it can be. This I would think would be pretty easy to make.
t.lay
Grayslake, IL
I've seen some posts about the angled bracket. I've got a 302 so it fit with just a modified mounting plate. How much taller is the 351? I've got something like 3" of clearance between my valve covers and the bottom of the h-boost.
rcmbronc
rcmbronc
Tomah WI
I am not sure how much higher, but the motorsports valve covers I am sure are not helping.
JKrieg70
Columbus, GA
This is what my angle bracket looks like bolted up to the firewall.
crawln68
Here's mine for reference. This is with a 5.0.
ransil
Crawlin68 How about some pic's of the linkage at the pedal and on the bracket.
mountain14er
Denver
Hey madgyver, thanks for the reminder on this. I've got the astro hydroboost and bracket sitting in the garage and was concerned about EFI clearance but I think I'll get around to installing it now.
crawln68
Here you go. Hope these help.
ransil
Crawlin68,
The Rod under the boot has it been modified to fit?
What is that make & model is the hydroboost?
I'm playing with an '84 Ford & '91 Astro trying to come up with the best fit.
rcmbronc
rcmbronc
Tomah WI
Crawln68, where did you get the angle bracket, or is it a stock Ford item?
crawln68
ransil said:
Crawlin68,
Nope, I used the original rod that came on the hydroboost unit and the stock EB rod to the pedal. So I didn't have to change/modify anything with the rods, it was a bolt on and go (or stop) addition to the EB. The hydroboost unit came out of an 84 Lincoln Continental.
Rmcbronc-The angle bracket is from JD. It made the addition of hydroboost a very easy install.
72Sport
I bought a JD bracket early this year and it is different than the one crawlin68 shows in his pictures. I also bought one of the ones off of ebay for $90 and sent it back.
The new JD bracket doesn't angle down where the master cylinder mounts like the stock bracket. I think it is made for the no fender clearancing booster. It is not dimpled where the 1/2" bolt goes through the bracket. The hole for the 1/2" pivot bolt are just drilled at an angle through the bracket. Which means the ends of the pivot shaft doesn't have much contact with the bracket.
The best bracket if you can find one is stock 76 77 in my humble opinion. I have seen three different designs of the JD bracket. He has been busy.
RFR2212
Chicago Burbs
On my bronco, we had to notch the back of the valve cover. No idea why I had bad luck, but it works well after we got the valve cover issue taken care of.
Gummi Bear
68 - you mentioned that your brake booster bolted right up to the bracket. Is that a stock bracket, or an aftermarket one? I saw that you mentioned that you got it from Duff's, but I'm wondering if it is stock dimensions.
72Sport
If you were to buy a Duff bracket today I don't think you would get a bracket that pointed the master cyl/booster down toward the inner fender. I bought one earlier this year and it was almost flat. JD has been changing things. I have a JD like 68, stock and 2006 JD model and all of them are different.
Look up posts by Desertthrasher. He posted about problems he was having mounting his hydroboost and his JD bracket. He provided pictures about hood clearance problems (same problem I had).
Note the position of the hydroboost. The boot barely clears the bottom of the bracket.
crawln68
I had to modify the JD bracket where the hydro unit bolts to the bracket. What I was referring to that “bolted right up” was the rod that comes out of the hydro unit was a direct bolt up to the JD bracket. In other words, I didn't have to change/modify the rod that comes out of the hydro unit. It was the perfect length.
Here is a picture that shows the tab that I had to add and the extra holes that I drilled in the JD bracket in order for the hydro unit to bolt up. (red arrows)
