hydroboost questions
panteramatt
My wifes 74 has manual drums and ps. It needs way better braking power. Can I add a hydroboost unit and it work with the stock ps? Why is the hydro so much better than vacuum? Could i do the conversion witht the drums and then out front discs on later without changing anything besides the brakes?
70_Steve
Old Guy
My thought...
If you're going to the trouble and expense of installing a hydroboost braking system, then upgrade the PS pump to a Saginaw pump. Not that much more.
Two advantages of the hydroboost. 1) It provides more boost which equals more pressure to the brakes. From the numbers I remember it's about double the brake line pressure of manual brakes. 2)If the engine were to quit running, you still get one or two assisted stops because of the accumulator on the hydroboost unit. Then, after the pressure in the accumulator has been expended, you have manual brakes, with absolutely no resistance from the hydroboost unit, unlike the vacuum booster, where, in addition to braking, you have to overcome the resistance of the booster.
The big difference in the drum and disc master cylinders is the residual pressure valve at the output connection of the master cylinder. I've read here where guys have popped out the residual pressure valve when changing from drum to disc, and had good results. But, as cheap as master cylinder are these days, I'd just get one for the proper application.
Apogee
Tangent, OR
i know you can not do it with out a dual return pump...
Actually, you can do it without a dual return pump, just with a tee-fitting instead. That said, you need to make sure there's no backpressure on the return side, otherwise your brakes will apply themselves under certain circumstances. The Saginaw pump is definitely better suited to the volume and pressure requirements of running both power steering and hydroboost though, so you might as well get a dual return unit if that's your plan. I beleive Hydratech is who most of the vendors source their units from...nice kits, new parts, and decent tech support, but definitely not cheap.
PaveBronco
go to a junk yard and look at any 90's Astro Vans, or large HD pick-ups they mostly came with Hydro boost units. you can find them on older cars/trucks also, they might need a rebuild kit. You can have a local shop make you new lines or get all the stuff from Jeggs or WH's they have all the fittings and lines. Saginaw is a must, I ran a T fitting for years before i found a dual return in an old Ford LTD. if you can find some F-150 knuckles with disks and prop valve could knock two things at once.
the-glove
Los Angeles
The best safety upgrade, I did was to put disc brakes on the front even without power assist.
I think this is what a lot of people agree on when I've seen other posts about hydroboost. If you're going to pick from either upgrading to discs on front, or hydroboost, being able to stop straight and shed water better during rain from switching to disc seems to be more important than boosting the ability to brake poorly by just switching to hydro. Of course much better to do disc AND hydro.
P
panteramatt
I will do it all when $ permits. So can I upgrade to discs with the stock MC til I can upgrade to the hydro?
MarkH@Wildhorse
Stockton, CA
The stock Thompson style pumps from my experience just don't have the volume or pressure to use with Hydro boot. You will need a Saginaw pump to take full advantage of the upgraded brakes.
wesleydax
adding hydroboost was by far the best investment i have made. should have done it 20 years ago.
