BoulderMike22
- Sep 26, 2013
- 98
I’ve installed a Astro Hydroboost, 1/2” clocking bracket to rotate 90*, and a Corvette style disc/drum master cylinder.
My first problem seems to be the HB does not engage the MC fully now that I have added the 1/2” spacer. I am assuming I either need a plunger rod from the HB to be another 1/2” or the adapter on the Master Cylinder needs to be 1/2” longer to get that immediate and full engagement of the two? Anyone know of or suggest an off the shelf solution?
My second question is about the pedal rebound. It’s fairly slow. From what I can tell, I don’t see any leaks. I re-sealed the piston seal so that’s fairly tight now. Any suggestions on what could be causing this?
