msweb
- Aug 29, 2003
- 2,377
It's a 90 F150, 5.0 with an automatic. The trans seems to be shot (just slips) but after a boost, the motor fired right up and runs smoothly! At Idle, it seems like the idle speed is too low so I'm hoping a good old fashion tune-up fixes that problem. Supposeldy, it's a remanufactured engine with 60K on it.... We've all heard that one before %)
It has A/C and power windows which I wish I could figure out out how to keep, a straight body and a good set of Mickey Thompson 32" Radial MTX tires on M/T "Classic II" wheels that will wind up on my 97 F150, assuming they're the same bolt pattern ;D
So, now I have my engine, wiring harness, ECU and inertia switch. I believe I'll also have an intake off a T-bird/Cougar to take care of the hood clearance problem.
Now... What else will I need? Inline fuel pump, return line to the gas tank, all new gaskets for heads, valve cover, intake, oil pan. New plugs while it's easy to get to them... I have a set of Headers for the Bronco that I hope will bolt right up... New 02 sensors? What else?
