I can’t decide
Snackslinger
Newbie
I have a 1974 bronco with a 347 with about 425hp. My c4 is trashed and does not have the hwy ability that I need. I am trying to decide which transmission to go with. I will run an atlas II. If I go the auto route what should I use and what will it cost? If I go standard should I go new AX15 and what will that cost with parts I will need. I’m leaning towards a 4R704. Help please!!!
33” tires
556 gears
This Bronco will spend most of the time on the road
blubuckaroo
Grease Monkey
Ridgefield WA
33” tires
556 gears
Yours sounds like it wants to be a tire burner.
An AX15 is too light.
The 4R70W is more capable, but the GM A 700R4 would be the best choice. It's got better gear ratios,.
73azbronco
My understanding is that the number after the R is the torque capability of the tranny, r70 is 700ft/lb capable. Plenty capable, problem is most use very used trannys, not top notch rebuilds.
jmhend
33” tires
556 gears
Just to clarify 556 gear ratio correct?
Build a 700r4 (but brackets and adapter will have a greater cost) or an AOD with the 4r70w gear set (no need for a computer).
Good luck..
Sent from my SM-N960U using Tapatalk
