Those of you with EFI, something you may want to read, just in case you run into the problem. Those without efi, maybe you'll find it interesting. I have made two versions. I was honestly about ready to go back to carb because it seemed that I had tried everything, and I just wanted to have it running. Enjoy!
Short moral of the story:
I had really bad hesitation, idle quality, and popping under the intake. I had basically replaced all the sensors trying to diagnose the problem, even though I was pulling code 66 saying that the mass air sensor reading was always low. I eventually traced the problem back to a short in the electrical system going down to the drivers O2 sensor, where water had worked its way into the harness and set up camp. I dried it out, fixed to connections, and it fixed the problem.
I have been battling problems intermittently for a long time now, and I figure other people may have similar problems, so I figured it would be good to share. So if you have similar problems, run a tester from the ground to the hot wire on the MA harness (when the battery is disconnected of course!), and see if there is conductance, if so, you have found your problem!
Long, drawn out story:
Lately I have been trying to figure out why I had been having a really bad hesitation with my efi conversion. Not only was there hesitation, but a popping comming from the intake, and a terribly rough idle that I couldn't get to smooth out for anything. I knew that all the sensors were new, and that I shouldn't have any problems with them, but I kept getting code 66 when doing the test with the engine running, indicating that the mass air sensor was always reading low.
I bought a new mass air sensor, thinking that the unit I had might be new, but I still got the code, so I tried another new mass air sensor, with the same problem. I have the new efi harness from fordfuleinjection.com that is similar to the mustang setup, so I was pretty sure that the wiring was ok. But, on the box that I recieved with one of the MAF sensors, it said that code 66 is an indication that there is a short in the system.
By using an ohm meter, I found that the MA hot wire was shorted to the MA ground, but where? I started digging around and found that the right O2 sensor goes into the same relay as the MA sensor hot wire. I have long tube headers and I had lengthened the O2 sensor wires so that the harness would reach them, but I used some of these white nylon screw type connectors, so I thought maybe they were causing the problem. Well, sure enough, I tore apart the lenthened section, and it was dripping with water.
Seems that I didnt seal it good enough to keep water out, but it could keep water in. I decided to solder the extensions and then shrink tube over the solder. Hooked the battery back up, and WALA!, smooth as I could ever hope for.
I had to miss Fabulous Fords for this problem, so I was a little pissed. But now I'm happy bacause I can make it to BBBB in June. And now people googling for info (like I have been for weeks) can find this and hopefully it will help them.
My setup, in case youre wondering: 97 Explorer intake w/act tapped into the upper intake, forfuelinjection harness, A9L computer, auto transmission, no emissions stuff, and I'm going to put a VSS on sometime.
