Sac '68 sport
Got my bronco painted at Maaco not quite a year ago. Had them sand it down to metal, body work, top of the line (for Maaco) base clear. Total $5K job. Had some issues with the quality of their work and things started off bad when they painted it the wrong color (resprayed on their dime), but they fixed most of what they could without painting it a third time.
I'm doing a body off so since I got it back about in June or so I've just been plugging along putting things back together. Today I went out to the shed to grab my grill and the drivers side that was toward the bottom of the shed (it and the tail gate were sitting on end) is bubbled really bad. I checked the tail gate and it's done the same. I'd post a pic. but I can't bear to go look at it agian. The tail gate also has a nice big circle of little bubbles smack in the middle too. I pulled the grill out about 2 weeks ago to check the fitment of the PS cooler and everything was fine. Only thing in there was the grill, tail gate and the parts for my soft top.
Before I take it back to get fixed, I'm wondering from the paint gurus if this can in any way be atributed to me leaving it out in the shed? Well I know that leaving it out in the shed caused it since no other parts did this, but should it have done this or is there a larger problem that can be traced back to poor adhesion, prep etc. When they repainted it the second time to get the right color on they did not prime agian. I know this because I sanded the bed rails to spray on Raptor and I didn't hit primer between the two color layers.
It's a small metal shed about 3x4x6 and the bubles are full of water. No rust has formed in them yet that I can tell. When you pop them clean water comes out. There was some moisture at the bottom of the shed and on the walls from condensation when I took the stuff out this morning and the parts were also damp but so was everything else outside. The gate also is showing some rust stains on the seems on that bottom side where the front and back pannles come together. I noticed on the grill that they did not spray all the way around the edge and onto the back side. On the side that was up in the air the little V where the ridge comes down to meet the hood is also starting to lift and has some rust under it too.
I had everything sitting on some pine 1x2's to keep them from getting scratched by the bottom of the shed. The pine was moist on the bottom but seemed dry to the touch on top.
I'm just wondering how much is my fault if any, and what I need to take resposibility for before I go in.
This really sucks cause on the stuff that they had to fix becaue they didn't paint it, they couldn't match the color for shit... Manager kept saying something about the pearl content of this paint (it's 97 Ford Calypso green metalic) and how the color can change dramatically due to humidity, temp etc when it's sprayed. I've never had that problem with anything I've painted but I've never sprayed pearl either. Does this also sound like a load of crap to you guys? I think they couldn't get it to match right because when they painted it the second time they re-sprayed directly over the other color that was quite a bit more blue so that blue tint is coming through.
