Steve
UPDATE - See my post on page 2
Short story: I bought a complete drivetrain (Howell-injected 302, C4 and Atlas 4.3) from a guy, who assured me it ran well and had "low miles." It was already pulled out of his buggy, so I couldn't test it easily and I trusted him. It's all installed and I've been messing with it for a week just trying to get it to run. The EFI works, I've traced all wiring, installed a new coil and tested the Mallory distributor. I finally decided to replace the plugs as a last resort, and while the plugs were out I figured I'd get compression readings for future reference. Guess what? The highest is only 115 and the lowest is 85. The engine is completely shot.
Right now I'm so pissed I don't even want to look at it, but eventually I'll get the drivetrain pulled. Here's the options I have:
- Get the engine rebuilt (if possible; I don't want to bore it too much tho to prevent overheating issues)
- Get a new or rebuilt long block 302.
- Go with a good 351W that a friend has.
Questions:
- What would you do? (It's primarily a hard core trail rig that's trailered if it's very far and only driven around town occasionally.)
- Is the 351W an easy swap?
- Will my current bellhousing, flexplate and torque convertor bolt to a 351W or would I need different ones?
- Will my current PS pump/bracket bolt to the 351W or would I need a different one?
If I go with the 351W, I'd swap the Howell over to it which would be easy. Anything else I should be aware of to figure out which way to go?
TIA
Steve
Questions:
TIA
Steve
