jeff68
I wanted to install the 5.0 from an 89 t-bird <br> (save some money kinda of thing you know)<br>But as I got started with the project, I ran into problem after problem, the final straw was the strong engine turned into an engine full of sludge and worn out even one of the main bearing was about to fail!<br>
total losses on this around $700<br><br>Starting over :
<br> Here is what I have done so far, I had the 289ci punched 30 over, the crank turned 10,000. refreshed the rotating assymbly, I added a set of 302 heads "rebuilt", new edelbrock 600cfm carb EDL-1405, new Edelbrock proformer intake, new edelbrock cam EDL-2122, , new oil pump timing chain and gears, new MSD billet distributor, new MSD offroader ignition box MSD-6470, new Summit SFI harmonic damper. new edelbrock elite valve covers and air filter cover. had the old flywheel resurfaced and a new starter ring-gear pressed on.new water and fuel pump. <br>Total investment this time around "a lot more"!!!<br><br>I am looking at installing the engine this weekend, there are a few things I need to get like plug wire, plugs and and oil filter. I'm also looking for a set of ceramic coated headers.<br>I can't wait to fire this thing up!!!!!!<br>Jeff<br>
