i need help despritly!!! pls help!
Broncass
PA
i have a nv3550 and the stock dana 20. i bought a twin stick from toms broncos and im having trouble bolting it. its a j pattern shifter. with the braket that came with my tranny for the 4 wheel drive, it just doest seem to work. any pictures or help would be great
thanks
craig :'(
BwoncoHowie
C-4 Wizard
thanks
craig :'(
If you are having trouble installing something that tom's sells, is sounds like you would be better off calling Tom's first. They may have seen this problem before and already have a solution.
B
Broncass
PA
that is all well an good but i have a different tranyy so wear the shifter bolts up is different. thank you for ur help tho. my problem is the nv 3550 and wear i bolt the shifter to.
trailpsycho
Broncass-
There have been several fixes on this posted before. The stick does not have to be cut and modified!! I dont have time to rewrite an entire post. Try a search on the topic. If you still cant find it and IF you would like, PM me with your number, I will give you a call or I can give you my phone number and you can call me. I can talk you through what I did to make this work. Its not that bad, dont worry. Hang in there, you are almost done! ;)
John
