Here's an update on my progress today. Knuckles and backing plates painted last weekend.
Pressed in ball joints, learned the upper joint zerk mounted on the bottom doesn't work with the axle shaft, packed new Timken wheel bearings with red and tacky, forged a spindle bearing knock out tool from an old screw driver using a torch and a BFH, pressed in new spindle bearings, assembled it all and...
dangit, the new rotor and hub is hitting the backing plate.
Scratched my head and had a beer. Then used a different spindle to mock it up. Mind you I have 4 sets of spindles for some reason and they are all slightly different. The ones that were super rusty in my OP were the correct ones. Luckily I had an extra set of spindle bearings to use. Now everything fits and spins without issue. Just need to add the calipers and torque it all down.
