blubuckaroo
Grease Monkey
No, it's nothing fancy like the triple pass radiator. But I really don't know specifics like fins per inch and that sort of stuff.
Typically, if you're overheating at speed, you aren't getting enough air through the radiator. It there anything (winch, PS cooler, electric fans, etc) that would block air flow through the radiator?
As an inexpensive troubleshooting task, just pull the radiator and take it to a shop. Explain the problem to them, and have they examine the radiator.
I've got to agree here. Some of you are listening to a snake oil salesman and have tons of money. That goes for "water wetter" too.
A good radiator shop is way better than taking a chance with advice from this site.
Usually there is a reason for overheating, not deficient stock parts. There have been a number of overheating cases here where the owner threw all new aftermarket parts at it and found the thermostat or head gasket backwards. A well maintained stock system with all the parts intact is hard to beat. The optional "super cooling" package that mine came with is all I have and it works great idling with the A/C on a 110 degree day. The "super cooling " package consists of just a three pass radiator and a seven blade flex fan.
