Dyehard
- Feb 17, 2010
- 231
A little history first: 76' Bronco with original 302 block, 93' Thunderbird EFI (H2M1 EEC), I added the resistors connected in delta to eliminate the EGR.
I checked my codes and get the following:
181-Fuel system at rich adaptive limit at partial throttle / system lean
189-Fuel system at rich adaptive limit at partial throttle / system lean
332-Insufficient EGR flow detected
552-Thermactor air bypass solenoid circuit fault
558-EGR valve regulator solenoid circuit fault
565-Canister purge solenoid circuit fault
Are any of these causing the others? Can any of them be ignored without consequences? How do I clean this up?
Thanks,
Steve
Thanks,
Steve
