You can probably get away with an NV3550, but you will have to cut a larger hole in the tunnel. This info can be found with a little creativity in your search words using the function above...several people talked abotu doing it, I am pretty sure they all succombed to the BL. The bottom line, however, is that there is always a compromise....you may not want a BL, but how bad do you want a 5spd?
If its a matter of $$, why fret over $100 BL when you will be spending $2K on a transmission conversion. If it seems like a pain to do the BL, then you are definitely not ready for a tranny conversion. IF its a look, stance thing. The 1" BL is barley noticeable.
The ZF or NV4500 definitely require more clearancing. For the 4500, a 1"BL and a BIG hole including removal of the channel under the flat part of the tunnel or a 2" BL and some trimming of the channel and a new hole. Cant say for the ZF. DOnt use the ZF tech article as an example, the 2WD model in the tech article was never ran--as far as I know--and is unproven. As for a 4WD ZF, do some searches and possibly pm some of the posters from those threads if you have additional Qs. IF you have any specific Qs on the NV3550 or 4500, ask away. Good luck.
