Identify a ZF trans by codes?
Banjer Picker
Talking to a guy that has a ford 5 speed tranny from a 95 F-150 behind a 302. He couldn't tell me if it was a ZF but he did give me codes. Do the following numbers help identify anything?
B693874
F2TA (I know what this means, but didn't help me ID)
KA
THanks,
Brandon
bigmuddy
Marthasville Missouri
Although I have heard some ZF's did come in the F-150's I have never seen one. Ask him if it has a diamond pattern on each side. If it does, it's likely a ZF, if not then keep looking.
Can't help you on the codes.
Ben
Bronco73
Cape Coral, FL
Same here, I have yet to find a F150 with a ZF in one. Another easy way to tell the Mazda and ZF apart is by the PTO cover plates which can be found on the ZF of both sides of the trans. From the numbers you posted I can not make out what is what. Tell the owner to get the code from the below the letters TR on the door jamb sticker.
Banjer Picker
Banjer Picker
I'm assuming that it is the Mazda tranny, especially coming out of a F-150...but sure was hoping!
JB Fab
Picker,
This might help......
Here is the ZF chart that shows what the codes are and what trucks / years that came in.
Jon
  • zf chart.pdf
  • ZF.pdf
