4R70W 4spd
A revised version of the AODE was released in 1993 with the Lincoln Mark VIII. Compared to the AODE, it has lower 1st and 2nd gear ratios for better take-off acceleration and was designed for better gearset strength. On vehicles powered by a 5.4 L V8, a stronger gearset is used than in normal duty 4R70Ws. In 1998, due to durability concerns, the intermediate one-way roller clutch was replaced with a mechanical diode providing extra holding capacity and longer service.
While there is speculation that the 70 can be multiplied by 10 to indicate the ft-lbs of torque this transmission is capable of handling including torque converter multiplication, (i.e. 700 ft-lbs of torque), there is no reliable source indicating this. In fact a Ford document stated that the 2003 "Expedition's 4R70W transmission is rated to handle up to 506 foot-pounds of torque, which provides a large performance cushion beyond the peak torque rating of Expedition's largest available engine."
http://web.archive.org/web/20040908...cle_id=548&press_subsection_id=423&make_id=92 . It is more plausible that the number indicates the torque handling capability in N-m, as 506 ft-lbs converts to 686 N-m which could be rounded to 700 N-m. The "70" may also refer to the transmission's torque capacity after torque converter multiplication which occurs at low rpm's when the torque converter is more "elastic". 4R70W stands for 4 gears, Rearwheeldrive, 70 is a measurement of horsepower and Wide gear ratio compared to the AODE.
The gear ratios are: 1st: 2.84 :1 2nd: 1.55 :1 3rd: 1.00 :1 4th: 0.70 :1 Rev: 2.23 :1
Applications:
1993–1998 Lincoln Mark VIII
1993–2003 Ford F-Series
1994–1997 Ford Thunderbird
1995–2004 Ford Crown Victoria
1996–2001 Ford Explorer
1993–2004 Lincoln Town Car
1994–1997 Mercury Cougar
1995–2004 Mercury Grand Marquis
2003 Mercury Marauder
1997–2004 Ford Expedition
1997–2001 Mercury Mountaineer
1996–2004 Ford Mustang
