My engine is a 302. Since the carb is a stock 2150 2V, I assume by too big you mean the physical size, and not the cfm rating? The carb fits perfectly to the manifold, gaskets and spacer, its just that if I do not raise it up a bit with the spacer and gasket, the linkage will not turn all the way as the bottom of it hangs on the top of the manifold. Spaced, it operates perfectly. Maybe it is a newer 2150 and the linkage originally was placed a little further out on the shaft to clear the manifold without a spacer?...
When I unplug a vacuum line, I get a huge drop in vacuum. I am thinking if there is a vacuum leak, it must be minute. I do agree the pedal linkage and a general linkage inspection is a good idea I will plan to do.
Thanks again for sharing your thoughts and expertise.
Incidentally Broncnaz, if I read your personal text correctly, Thank you for your service to our country!
Bill
