dprio34
I was trying to match up my door keys with my ignition key today, but after removing the ignition cylinder and then the ignition switch, I discovered the ignition wires (yellow and red/blue) both had been spliced badly by the PO. Both Yellow and Red/blue came loose. Got both soldered and re-installed the switch and key cylinder on the dash panel. Now the Bronco will not start. It seems there is no "pause/stop/detent" when you turn the key to START and ON from OFF. In both OFF and ACC you can feel the detent. Additionally, it seems very hard to turn the key clockwise. Does anyone know if I stripped out the tumbler or the entire switch?? Any help/suggestions, most appreciated. Thanks. Don
