BrettKoenecke
- Aug 6, 2014
- 115
Hi there. I am stumped tonight. I have a '73 with 302 and C4 AT.
Bone stock, runs like a champ, usually.
Problem: Ignition key will not engage the starter. No click, no nothing. Turn the key to start and nothing happens.
Plenty of battery, that isn't it.
Starter will not engage in either park or neutral.
Checked the Neutral Safety Switch with an Ohmmeter. It checked out OK.
Jumping the solenoid made the starter turn over.
The motor would then run if the key was turned on, but would not if the key was not turned to run. The stereo runs when the key is turned on. So the key is working somewhat at least.
I presumed the solenoid was the problem so changed it out tonight. No change in the situation.
Either the NSS is needing adjustment or the ignition switch needs help. Thoughts? I could use some experience tonight. Thanks in advance.
