So I’m removing my dash and everything is pretty smooth up until I try to remove my ignition switch. I do the paper clip trick to move the key counterclockwise from ACC. No matter what I do, the center hub with the key will not come out. I have gone back to neutral and repeated the step multiple times with the same result. In addition, now the key is hard to remove and there is obvious internal resistance when turning the key to the start position. It seems that something internally has moved.
Any ideas? Assuming this will not come out in 1 piece. Suggestions for removal so I can buy a new ignition switch.
