...Being color blind and it's been 20+ years since replacing one, would appreciate a bit of guidance here.
Since you're color blind and those colors are odd, faded and have stripes, here's the basic rundown to make sure you're starting from the same place:
1. The wire on the center stud is the Red w/blue starter relay wire. I think I even see an "ST" next to it.
But is that a second wire crimped to the same connector? Can you get another pic showing it's stripe better? Looks black, but not sure. Could be another Red w/blue stripe wire for the Duraspark module.
Looks like Quick n Dirty has the same colored wire on his. If Ford had them both at the switch, rather than spliced together somewhere up the line, then one goes to the starter relay's "S" post (through the neutral safety switch if an automatic) and the other goes to the Duraspark module.
2. The wire almost covered by the first one, marked "BAT" is the Yellow power feed wire to the switch.
Consistent so far...
3. The remaining wires, located at about 2 o'clock marked ACC are your Red w/green and your Green w/red wires. These should actually be the ones on the IGN post you were asking about.
They should be IGN only so that you can turn the key to ACC and not power up either the voltage regulator/alternator or the ignition coil.
Normally, the Red w/green wire is your resistor wire further up the line. It will change to pinkish brown if it's under the dash, but I've seen some diagrams where they put the resistor wire between the firewall and the coil, on top of the engine. Never seen one there, but I think someone recently found theirs exactly there. Odd, but true...
4. Seems to be missing the factory Black w/green ACC wire.
Pretty critical, so wondering where all the power gets to half of the fuse panel?
5. Also missing the odd colored (Pinkish?) wire for the Brake Warning lamp on the dash. This switch may not even have a Proof Out connector (grounds to the dash only when in START) so it could have gotten tied up under the dash somewhere.
Not as critical as the Black w/green wire obviously, but still be nice to find it.
Good luck.
