DU 001
Replaced my ignition switch while doing a complete new dash (dash cover, new switches, knobs, autometer guages etc...). Key did not return properly when I cranked the engine and/or I hooked something up wrong and had a small fire and wire meltdown. (Almost pulled the pin on the Halon Extinguisher).
If you follow the 2 main flow lines off the brake fluid resevoir, there are 2 wires that plug into something inbetween them. They are purple and purple/red from what is left of them. They join up with a black/red that comes from rear of truck and they then plug into 3-way plug driver's side firewall area. black/red wire ok I think but purple boys are FRIED.
The above harness also joins up with the front and rear light harnesses (4-way plug driver's side firewall); miraculously, I don't think I seriously damaged any of them.
Headlights, running lights, brake and hazard lights ALL work both front and rear. I will replace any suspect wires as a precaution but at least they all work. Can't check blinkers.
Can someone please tell me what the heck happened and what the 2 purple wires are/were that I fried? What do they plug into inbetween the brake lines? Am I totally screwed or can I get a replacment plug and run 2 new wires back to the ignition again assuming all else is ok?
Fellas, please be gentle, I still smell like an electrical fire while writing this...
Any help would be VERY MUCH APPRECIATED. Didn't see the fried purple twins on a wiring diagram but figure someone knows what's going on here?
THANKS IN ADVANCE,
DU 001
THANKS IN ADVANCE,
DU 001
