Finally making progress on Frank!!
well i got the screws across the windsheild out, the wireing out from behind the dash, and finally the dash is out! Problem, is I have the shifter linkage unhooked, and the steering knuckle from the steering box, and the clamp loosed by the firewall. where do I go from here in removing the steering column. The U shaped bracket from under the dash is loose. Does it just pull out thru the dash area now or is there something else to unhook?
Bronco Ben
In the beginning, frank as it sat when I brought em home. Kinda rough isnt it!
Bronco Ben
