lca'73
OK, so here's the deal. My fuel gauge has never worked properly, but for different reasons that I thought I had fixed. Now we have put the truck back together and checked all the wiring, checked the gauge, the sending unit and grounds and it still isn't working. Here's what's happening.
We bench tested the sending unit with the gauge attached and they both worked and synced correctly, all the way empty to all the way full, the needle moving with no problem as the float was manipulated. Put it on the truck. My painter/body guy put just enough gas in it to get it on and off the tow truck to get the exhaust put on and then we took it home.
Got it home, ran it and realized the gauge was on E, but figured it was because there was not enough fuel to register. Put 5 gal in it, still nothing. Crawled under and tested the sending unit, read 46, which was pretty much right on since we had already driven it around the neighborhood a few times. Took the ground off to see if it would ping past full and it didn't affect the gauge at all. Curious if the ground in the gauge has something to do with that or if the tank itself is also somewhat grounded, preventing my little test from working.
When you start the truck you can see the needle rise from it's resting position to "E", but it doesn't rise above that. So it is getting some kind of info and is not pegged past "E" and does go back to it's resting position when the truck is turned off. It moves at the same smooth/slow speed as the rest of the gauges.
Also, another concern and question that is gas related...has your sending unit ever gotten loose after driving and started leaking gas?? As we were checking the sending unit and moving a gas line, the tank started pouring gas around the sending unit because it had gotten very loose and we know with certainty that it was tight when we put it in. Is this a concern?? Should I be checking this connection frequently?
That being said, after we lost some gas and tightened the sending unit again we checked the reading and it did go up to 51, so it is reading correctly. There are no problems with the sending unit or float. There were no problems with the bench test and it does seem to be getting some kind of info...just not enough to make it correct.
Help!
Also, I only have one tank and it is a 12 gal. so no issues with switches either.
Thanks in advance!! This one has gotten tricky.
Help!
