If its a head gasket issue i can see that but a coolant check could prove that. If the total timing is out i can see that.,if you have a fuel pressure issue i can see that. At this point i would be checking for a plugged exhaust or plugged cat especially if you have sluggish performance problems. I dont under stand a head or valve problem as those parts dont change in use making an engine run hot.
Exhaust is dual full length headers, recently ceramic coated and dual 2.5 inch Flowmaster Mufflers w/ turn downs just before the rear axle. No Cats or any other b.s. to keep it from breathing. The exhaust seems to be breathing great, especially with the new ceramic coated headers.
But the damn car still overheats... and only under a heavy load.
